OIS in camera?
Discussion in 'Mavic Pro Discussions' started by kmaluo, Nov 30, 2016.
  1. kmaluo
    kmaluo Well-Known Member
    Oct 14, 2016
    423
    114
    Sorry for the dumb question, but I assume that since the camera body shakes so much in flight, that there is OIS in the camera itself? Thank you
  2. Kilrah
    Kilrah Well-Known Member
    Nov 12, 2016
    620
    170
    Switzerland
    Nope. Small linear shifts like that are unnoticeable as long as rotation is compensated, unless you're very close to a subject.
  3. kmaluo
    Oct 14, 2016
    423
    114
    Sorry, I don't understand. How is the video feed being stabilized when the camera is visibly shaking? Every little motion on my point and shoot camera is easily seen on it's display when OIS is turned off.
  4. The Editor
    The Editor Well-Known Member
    Oct 12, 2016
    398
    209
    The gimbal stabilises on three axis, accurate to around 0.03 of a degree so it does a remarkable job of ironing out the movement
    kmaluo likes this.
  5. Kilrah
    Nov 12, 2016
    620
    170
    Switzerland
    It isn't, but... what I said in the post above. What's very apparent is rotation/change of angle, and that's taken care of. Shifts are not noticeable unless the subject is very close.
    kmaluo likes this.
  6. kmaluo
    Oct 14, 2016
    423
    114
    Ah ok, so the shaking I see is the gimbal doing its thing. Just seems from my stationary vantage point that the Mavic is pretty calm, but the Camera is going wild. Everything is mounted securely. Thanks
  7. The Editor
    Oct 12, 2016
    398
    209
    The gimbal shaking is it moving on its rubber mounts.Tnese are designed to take up most of the high frequency vibration but cannot do much for lower frequency movement. It is a suspension system and pretty crude design and compression mounts are much better at absorbing the movement however, the movement of the gimbal you are seeing is actually countered by the brushless gimbal.
    They are very efficient at what they do.
    kmaluo likes this.
Loading...
Similar Threads - OIS camera Forum Date
Newbie From Illinois Pilot Check In Dec 30, 2016
DJI doing a bad job creatimg the JPG (way too much denoising) Mavic Pro Discussions Dec 12, 2016
Ticking noise when turned on? Mavic Pro Discussions Dec 7, 2016
Noise control during night time is bad.... General Discussions Nov 19, 2016
hello from lockport Illinois Pilot Check In Nov 4, 2016
Share This Page
