Thanks for your answer on this, I'm hoping you can help out with my follow up questions.People have tried it. It's too slow to run DJI GO. You'll need at least an iPad Mini 2.
And one more question. Is it worth getting one that has cellular ability for the additional gps function in the iPad? I do not plan on buying a data plan for it, but I'm wondering if even without being on a cell plan, is it a good idea to get one.
Performance-wise, you likely won't notice any differences when using DJI GO and Litchi. The iPad Mini 4 is lighter, has a faster processor, has a brighter screen, has an anti-reflective coating on the screen, and is less prone to overheating when flying in hot temperatures.
You'll be able to use the Follow Me feature and reset the home point to your current location after taking off. If you don't plan to use those features, then save some money and get a Wi-Fi only iPad Mini. The cellular models are even more expensive if you buy one without a data plan.Is it worth getting one that has cellular ability for the additional gps function in the iPad?
Yes. Everything will work other than the two features I mentioned above.if you don't have GPS, will your Mavic still show up on the map display
You do not need a data plan if you're using an Apple device. The GPS will work either way.I have a tablet with GPS. Are you saying in order to use the GPS in my tablet when flying the Mavic I need a data plan for the tablet?
If you're referring to using GPS on an Apple device, then, no, you don't need a data plan. You only need a cellular Apple device since Wi-Fi only Apple devices do not contain GPS receivers.Im confused, no need for dataplan if using apple device ?
