If you exceeded 7km the battery would die before you got back.Has anyone here actually exceeded the 7km mark with parabolic range extenders? Just curious as mine are coming in the mail and want to understand strengths and limitations.
I got a set from my local Best Buy store a couple of weeks ago. The finally have the Mavic and some a few accessories in stock. I have tested them five different times at different locations on 2 different days just to rule out erroneous interference issues. I actually had better signal strength without them. With the parabolic extenders on I had gone down to 3 bars of RC signal at aprox. 5,890ft travel distance where I routinely fly. I removed them and the signal went to full strength. I know I had the RC antenna pointed correctly (according to map coordinance) so I would have to say "nay". I am looking real hard at the DBS antenna mod called NanoSync which is designed exclusively for the Mavic Pro.
Yes it will, if you do anything to your mavic it will void it.I'm ashamed to admit it but I've got those nanosync antenna on my work bench but I'm a little nervous to open up the controller. With so many flyways happening not sure I want another thing to worry about. Plus not sure if it voids my DJI refresh policy. They do look cool and much more of a antenna look to them !
