I'm coming from a Phantom 3. Can someone please explain the focus on the Mavic. I get you have to touch the screen. When recording video, Does that mean you have to keep touching it as you fly?
I wish they would have just made it auto focus, They must have saved a whopping ten cents there.When you take off, take it to 130 feet, point your camera down to the ground, touch the screen, now you're set for the rest of the flight ......
You can choose between CAF (continuous auto focus) AF(auto focus or tap to focus) or MF (manual focus using the slider). CAF is in my mind awful as it will randomly choose to focus on something in the middle of your shot and you will see the camera searching for focus. It doesn't care if you're recording or not. I'll put it in AF, tap on an object far away so it's focused at infinity, then switch over to manual focus where it will stay at infinity and not change even if you touch the screen for any reason. Focus peaking is a great tool as well.
Thanks for the suggestion. What is focus peaking?
I disagree. I use Auto WB all the time outdoors, and it's doing a fine job. NEVER is a rather harsh statement.Also pick a white balance and go with it, NEVER use Auto WB it will bite you in the a**! In fact when it comes to these flying cameras auto anything is a really bad idea.
that is a good idea about the button in the back to focus. How do you go about doing that if you don't mind. That is GREAT IDEA for the under belly buttons.No, you touch the screen when you want it to focus so where on the screen, and then it stays like that. You don't have to oeuvre your finger on the screen. On the controller, you have behind, two bottons that you can custom on which action you want to accomplish. You can program them to focus, so you don't have to always touch the screen!
