Red LEDs not staying on
tony56shooter
After I sync the remote control with the Mavic and start the app the front red LEDs go off. How do I turn them back on?
Thanks again for the help,
Tony
You can turn on the front lights in the following section of DJI GO:
Take another look. It's there. You'll need to scroll down since those menus are long.
This is what I see below the return to home set in the advanced setting area.
I'll try and scroll down more but I'm pretty sure I went to the bottom. I just started flying last Thursday and have had a ton of fun.
Reactions: boxsterfahrer
Ah -- you're using an Android device. Disable the following setting:
If you are recording video during your flights, you may have to turn on front LED's by turning them off in your camera settings.
This is what it looks like below Front LEDs Auto Turn off. this may help you help me. They turn off when I feel the remote control or the phone vibrate during the time the app starts up.
There are,2 areas of the settings for front LED's. In the settings of your image attached, they should be turned on. In the main aircraft settings they should also be turned on.
I know it does seem confusing, but this is what you will need to do to keep them on in all modes of flight recording or not.
This is a short video of the red LEDs coming on and then going off at start up.
Since you're not able to access the "Turn on Front LEDs" setting from my first screenshot above, you'll need to turn the LEDs on/off using the C1 or C2 button (on the back of the remote controller). You can program those buttons in the following section of DJI GO:
Reactions: Drone Master
karthikeyan103
