Registration numbers
snowman9031
I see that you are supposed to label your drone with your numbers. Is there a certain spot or anywhere. Does anyone have any pictures of there spots. Or just list where of they don't want numbers shown.
If you're a hobbyist, you can display your FAA registration number in any location that is accessible without using tools. I put mine on this small label and attached it inside of the battery compartment.
Reactions: VMDoug and Rbruz
I printed mine on a label maker and put one in the battery compartment and one on the leg with the weird box graphics.
I also printed mine and put it inside battery compartment also put one on the front arm. If someone found it they might not know to look in the battery compartment.
Reactions: Bunny Too
on arm plus my Ph # is on a reward folder on ssd card
Did that with my phantom 2 and i work
invertedloser
