If you can get it to run for long enough to update your firmware on the RC and Mavic it may well come good. That was certainly the case for me. DJIGO 4 was always crashing for me and disconnecting. As soon as I did the latest firmware update it came good.OK. I gave it a shot. The Samsung S7 Edge is NOT compatible with the DJI GO 4 app. Doesn't connect, complains about the WiFi, and then spontaneously shuts down.
Better to adjust your expectation to late 2098. jusayinI've got the S7 Edge and waiting for early 2098 for my Mavic to arrive.
I first updated the firmware and then tried the GO 4. It instantly complained about my wifi and would not open a video channel. As I worked to try to resolve the lack of video the app shut down twice. That's enough negative for me to just keep using 3.If you can get it to run for long enough to update your firmware on the RC and Mavic it may well come good. That was certainly the case for me. DJIGO 4 was always crashing for me and disconnecting. As soon as I did the latest firmware update it came good.
I've got a big flight coming up and will use the 3 set up (Hawaii mountain top to ocean). When I return, I'll try 4 again including different cables and inputs. 3 has been very stable for me after the second update so I'll stick with what's working. Good to hear others have gotten 4 to work. It looks pretty cool and more advanced.Got a Mavic now, 3 test flghts perfectly done with S7 Edge.
Get rid of the low Quality DJI cable, use a normal micro USB to middle USB port on the Tx.
Ender
Sweet. good to hear it is working well for you. When you get a chance try the Follow Me mode to see if your Mavic jumps around as it follows the phones GPS location. That is the only thing I can fault when paired with my S7 Edge, but it is trivial.Got a Mavic now, 3 test flghts perfectly done with S7 Edge.
Ender
Will do !Sweet. good to hear it is working well for you. When you get a chance try the Follow Me mode to see if your Mavic jumps around as it follows the phones GPS location. That is the only thing I can fault when paired with my S7 Edge, but it is trivial.
Will do !
Currently i have only flown in between rain pauses from my home but when we have less rain i will go in a wide open area and try out stuff... Was creeping hrough the yard in tripod mode which also worked fine
Still funny Sports mode is called that name as the mavic still flies like a bathtub compared to ,ost of my crafts
But its great as a Hybrid but i would have called it "less gentle mode" ;-)
Ender
Ender, dude, that is exactly why you still have your other craft!
Got to remember this is a commercial bird, imagine the carnage if it was able to do 60mph out the box
Works like a champ with my S7 edge.OK. I gave it a shot. The Samsung S7 Edge is NOT compatible with the DJI GO 4 app. Doesn't connect, complains about the WiFi, and then spontaneously shuts down.
I posted this elsehere but works well with the S7 edge. "Auto Clean up video cache" makes it work in a continuous loop with old stuff getting replace by new. Should fix it crashing like that, although mine only ever popped a cache full message when I was not using this feature.It does work well, ...........Also make sure if you cache video files you have plenty of room on the phone, otherwise it will just crash.
