Slight change in flight controller design?
1dr1
There have been several threads showing an iPad mini 4 being placed directly between the FC handles.
I can't get my handles to open that far. In fact, there is even one thread suggesting that the right handle, if fully extended, would contact and interfere with the operation of the Sport mode button. My handle doesn't even come close to the button, regardless of how the handle is positioned.
A small design change to reduce the chances of activating Sport mode, which also incidentally prevents using the iPad mini between the handles?
Anyone else notice this?
Received a Flymore combo through Newegg on Nov 21.
With reference to the Sport Mode button being accidentally activated.
IMG_0539.JPG The CLOSEST my right handle comes to the Sport mode switch is about 2mm.
Other than the filing process, I wonder if the switch could be turned upside down.
I don't know , I can fit my 8 inch galaxy tab s2 in it just fine
Hey Laura,
I thought you were looking for the "s" clips. Did you ever find those? I'd like to get some to use with an Nvidia Shield.
Thanks
Sent from my iPad using Tapatalk
I'm considering that one .... is it possible to show a picture of it in the controller?
Here you go....
refrigasketscanada
