Kilrah
Free File Hosting - Online Storage; Upload Mp3, Videos, Music. Backup Files
No account, no nothing, you just get a link to post.
for flight data? yikes, can I assume this is some raw text file that can be radically compressed for sharing using ZIP?303MB for a 15 minute flight?
Nope it's a DAT file.for flight data? yikes, can I assume this is some raw text file that can be radically compressed for sharing using ZIP?
I tested it, the DAT file can be compressed significantly (64% original size) to make the upload smaller for sharing. I used WinRAR but you should be able to use the more common zip to achieve the same, just because the friendly folk who examine your DAT may not have WinRAR, but most certainly can unzip it, as modern OS has zip built in.Nope it's a DAT file.
I hope that the guys here are able to help diagnose what happened to you Mavic so you can get back up flying soon. Hopefully, it will all turn out well between you and DJI.Hi all! Hoping to get some help from you guys about todays crash. I was out for a typical routine flight above a friends house. I had been cruising around for a while and decided to flip into sport mode. As soon as I pitched forward in sport mode, it flipped (I think) over the front left corner and proceeded in a succession of summersaults to the ground. The results aren't pretty. The gimbal/camera are almost completely ripped off, the front right landing gear/antenna is broken, and the top of the body is popped up. I'm guessing either a prop or a motor failure although it could have been one of the small birds in the area. I was hoping I could get someone to analyze my flight records for me and tell me if it was my fault or if DJI is likely to eat this one. First though, I need to know how to upload theses records to this sight. Thanks in advance! -CF
Thanks Beachcombing! I guess my writing curriculum is paying off! -CFI hope that the guys here are able to help diagnose what happened to you Mavic so you can get back up flying soon. Hopefully, it will all turn out well between you and DJI.
But I just wanted to take a minute to thank and praise you for posting such a well-thought out, well-written, logical, intelligent post. I never would have guessed that you are only 15.
I'll be waiting for them.Good news! I am currently downloading my DAT files to Box Drive! I did have to compress them into a zip file. Should be able to post a link as soon as it downloads (we have very bad internet at our house).
This appears to be the wrong DAT. I see no motor activity. It appears to have been carried around inside a building.OK here is the link to the DATs! I hope this is the right one, let me know if there is a problem or if this isn't the right one. -CF
Sigh. Guess I'll have to try again. Sorry. How many MB should a 13 minute flight be?This appears to be the wrong DAT. I see no motor activity. It appears to have been carried around inside a building.
A 13 minute flight usually exceeds 400MB, that it breaks off into a new file. Look for a file at 400MB and then add the file right after that one.Sigh. Guess I'll have to try again. Sorry. How many MB should a 13 minute flight be?
Sure. Zip them all up. Make sure it's of the day of the incident.there are about 5 files from that night, one is 303MB the others range from 2.2MB to 22MB. Should I just upload all of them?
