Vision Pilot 3 (iOS Waypoints Mission App) Available Now
Discussion in 'Classifieds' started by ocatcr, Nov 30, 2016.
  1. ocatcr
    ocatcr Well-Known Member
    Approved Vendor
    Nov 2, 2016
    68
    29
    Available at iOS APP Store
    Vision Pilot 3 will enable you to safely and reliably shoot high quality aerial video.
    Supported Platforms:
    • Compatible platform: DJI Mavic, Phantom 4, Phantom 3 (Pro/Adv), Inspire 1 (X3/X5/X5R), Matrice 100
    • Compatible iOS devices: iPad Air/Air 2/Pro, iPad mini 2/3/4, iPhone 5s/6/6+/6s/6s+/SE
    • Required DJI firmware: 1.4.10 or above
    Features:
    • Active Track: the aircraft can track a moving object you select on the video preview, you can also Orbit around the tracked object / have the aircraft automatically follow the subject.
    • Supports Waypoint / Panorama missions / Focus Mission
    • Panorama mission: easily shoot 360° horizontal and spherical panoramas
    • Waypoint mission: pre-plan waypoint missions without being connected to the aircraft
    • Focus mission: keep focus on a subject while flying aircraft with various orientation
    • Exported log file can be uploaded to HealthyDrones for flight data analysis
    • Pre-plan waypoint missions with web browser at https://vision-pilot.com/planner
    • Mission sync to all your iOS devices
    • Supports Goggles Mode (iPhone only)
    • Navigation Map and FPV Display
    • Real time battery level indicator
    • Warning monitor system
    • Screen Recorder
    -- Waypoint mission
    Features:
    • Setup classic Waypoint missions (eg. Cable Cams, Selfies and etc...)
    • Pre-plan Waypoint missions without being connected to the aircraft
    • Supports multiple Points of Interest
    • Adjustable Bezier curves path for smoother videos
    • Automatic gimbal control
    • Play/stop/pause/fast forward/backward the mission on the fly including gimbal movements
    • Load and save missions
    -- Goggles Mode (iPhone only)
    Enter the cockpit and see with the eyes of your drone - Vision Pilot 3 turns your VR headset into high quality FPV goggles.
    Features:
    • First Person View (FPV) optimized for VR headsets.
    • On-Screen-Display (OSD) shows live telemetry data such as battery level, height or camera orientation.
    • FPV mode allows to switch the video preview between drone camera and iPhone camera.
    • Toggle Full Map and FPV mode.
    • Battery and IMU monitor system.
    • Remote settings control without touching the screen.
    • Screen adjustment for different goggles, iPhone
  2. JoshuaCarlton
    JoshuaCarlton Well-Known Member
    Nov 6, 2016
    120
    82
    This looks promising, it would be cool if you could hit play on the mission and just run it as a simulation to make sure your heading is correct.
Loading...
Similar Threads - Vision Pilot (iOS Forum Date
Vision Sensor Calibration issues Mavic Pro Help Sunday at 1:54 PM
calibrate vision sensors Mavic Pro Help Saturday at 9:55 PM
Downward Vision Sensor Mavic Pro Help Mar 20, 2017
Slightly blurred video vision but tack sharp when paused Mavic Pro Discussions Mar 11, 2017
red sign of vision sensor Mavic Pro Help Mar 8, 2017
Share This Page
