So I recorded a lot of video on many flights. Each flight I start recording before takeoff and stop recording after landing. As you can see, there is a lot of fluff and only a small segment of each flight video is useable. I want to create one long video that is a combination and compilation of slices and segments from the many videos that I had recorded using the Mavic.
I recorded them all in 4k using the 24fps, no editing or post processing or anything whatsoever yet.
Is there a simple way of using a software or tool that can just allow me to slice and combine without having to spend time to convert/ process /etc?
The reason I'm asking is because I noticed that whenever I do use Adobe software to do such a compilation the end result is NEVER anywhere near as sharp as the original 4k MP4 that the Mavic spits out on my microsd card.
So in theory why can't it be possible to use a tool just to tell it to slice at this time index for each video and then combine them without having to spend hours of "rendering" or processing or whatever, and most importantly without having to reduce imagine/video quality. I mean isn't there a completely lossless way of doing this?
I'm not even doing anything complicated like adding music, speeding up or slowing down time, transitions or any other effects etc, since they are ALL recorded from the same Mavic at the same 4k 24fps in the same format MP4 unto the same microsd card there should be an easier way to do what I'm trying to do, not to mention it could be completely lossless rather than suffering an image degredation
any tip?
any tip?
