Where are you locating your FAA numbers on your Mavic? (Inside or out)
CactusJackSlade
Just curious....
They can certainly be inside the battery compartment as per FAA rules... but I prefer mine outside and visible, also have phone # and "Reward if Found"
I also added some bright yellow to the front legs and canopy nose area for easier orientation.
On the top, inside, on each battery and on the controller. The label includes my name, address, phone number, issue date, expire date and FAA Registration Certificate Number. Annal enough for you? Oh, and I'll soon be adding it inside and outside of the carrying case.
I placed my label inside the battery compartment.
Reactions: Andrew F
Is the issue/expire date really necessary? Surely anyone needing to look up the reg. will get that info anyway. Just asking :)
I placed a label inside battery compartment and another on the back of the Mavic. Why 2? I have no idea, but I have my telephone number listed under registration.
Inside the battery compartment.
Is there a reason to label vs. using a sharpie? What labels are you guys using?
With my P1 and P3A I just tattoed it on the bird, but I guess that poses a problem if you are planning on ever selling it?
Completely up to you.
I have it on a piece of masking tape inside the battery compartment.
I put mine right next to the SD card slot
I put the FAA number label inside the battery compartment and the label "Reward if Returned" with a phone number on the side of the body.
Thanks guys! I will try some pink (black) tape that I can write on.. seems good enough for now.
I printed a tiny label and put above the light panel on the rear of the Mavic
Sent from my SM-G935V using MavicPilots mobile app
I printed and extra copy of my FAA license. Cut out the FAA number.. laminated it and taped it on the inside of batter compartment. If I ever sell the drone I can remove it.
shakes60
