“Take off Failed” error code: 30226
cknipp
Tennessee
I’m getting this takeoff failed error code 30226 on my Mavic mini. Any advice? I follow the prompts to turn off the app and restart etc. Keep getting the same code.
Help!
CKnipp
Help!
CKnipp
Have you performed any updates recently? If so, perhaps one did not go well and re-installing will resolve the issue.
Why yes! As a matter of fact I did try to run some updates recently. ? That could be the problem. I will try to re-run updates and try to fire her up again.
Thanks!
CKnipp
What happen if you do not connect the phone and start the drone? Does it do its 'dance' and can you start the motors etc.?
I’ve had the phone connected each time. The camera would connect, but
the motor would not start. No propeller movement.
Hello,
In my case it was bad (old ? why ?) firmware.
After firmware update in DJI Assistant, everything goes normal.
KiKiHUN
