I had a
Mavic Air 2. Different battery and lights but very similar charge/discharge software on both.
Does that battery have all the small multi-buss pins where it plugs to charge, monitor, and balance each cell in the full battery pack?
I use a Hanatora 4X charger also.
Had this same problem before. I can’t remember the full technical explanation of why it did this but I will try to explain the problem and remedy.
Need to take it off the Hanatora and make sure that the fault battery is at room temperature.
Then plug it into DJI stock original batter charger. Leave it a minute or two and see if it goes to 1-2-3-4 charging up lights.
If it does, leave it alone so it can balance up the individual cells in the pack. To reset the chip in the battery if it sees this problem.
Fully charged, remove it from charger and the lights should go off, back to normal. Then fly down that battery a usual flight to about 10-15%. Land and see what the battery is doing. If it faults and freezes again, you may have either a bad cell in the battery or bad pins connecting to it.
if no matter what of the above it just stays on, may need to fly down that battery way further to force all cells down to similar power then to charge up together, on the DJI stock charger.
Safe Flying,
KI5RLL
