As mentioned by @iaincaradoc above, please refer to the manual as there is good information in there.How do I make a 360-degree view of the interior of a church with M2P?
I don't want to make a "tiny planet". I want a picture that people can scroll around and see the entire interior.
My concern here is that you will be inside a building and as such you will most likely not have GPS coverage. If the drone is in ATTI mode, then it won't have the ability to hold its position accurately as it builds the pano shot. I have never tried a pano shot without GPS so I don't really know if it will even work.
I would consider the Insta360 or Insta360R or Gopro Max. All can do what you need with a lot less work and all will take the 360 image seamlessly. The only consideration is to use a monopod and have the camera directly aligned to to the top of the monopod to remove the view of the monopod itself. If the camera is tilted at all, then you will see part of the monopod and it will be hard to remove in post.
Paul C
I posted this for someone the other day, hope it helps.
1 Take a 360 sphere panorama in Go4
2 Stitch together with DJI Media Maker.
3 Upload to Kuula Pics
4 Post link on forum.
Had to reduce the size of the file to host on Kuula Pics
Hi Cyborg
Just wondering why u are doing step 2, the drone already has a stitched pano jpg file in the directory above
just wondering if its quality. I cant get Media Maker to work, it fails during the stitching so cant test? I can’t have spotted it
