First off I'd like to say that the way this drone handles and the feel after being dialed it truly amazing!! My other drone is a MA2 which I'm very fond of, but the feel of each drone is diff, I like that. I'll use each for different purposes.
My first question is about the prop storage. I bring this up because my first drone a MM, after a solid yr of use it developed a problem with prop warping from storing and I tried each and every time to carefully store away with the props at a 90 deg angle. It was fine after changing the props, but the error message pointed this out for me. Even from the first use of the M3P this caused concern but all pics are show interlocking of the props when stowing away. Is it fine because of the change on the arm angle? Time will tell I guess.
My next question concerns leaving a new, never charged plus battery in hibernation mode. How long will it safely store in that state. I thought I'd leave it for backup down the road, since I have 2 drones and 6 batteries.
Also I have ZERO problems with range and connection and the map function has cleared itself of being slightly blurry at the beginning of use for some reason.
