ABOUT DRONE MOTOR KV
if this is a serious post, then it sounds like you have either wired up the motors wrong ,two should go CCW and two should go CW and they should be diagonally opposite each other,or you have the props on wrong
Reactions: THE CYBORG
Thanks for all.
The motors and ESCs and the props all installed correct. Each motor runs well both in speed control and direction when do the test individually.
The phenomenon is:
one motor runs first, the other 3 motors run as the control rod tilt more.
should I move the control rod fast?
Best
Thanks for all.
The phenomenon is:
Best
The reply from @slup is your best course of action to get the information you seek. The FPV guys build, test, and fly their own craft all the time and are very knowledgeable.
You do have a problem as all four motors should apply power at the same time.
Thank you.
I'll go @slup 's ref. to dig more.
Best.
KiKiHUN
