How do you down load data for a Mavic Pro Platinum? Have looked at all the files in DJI Assistant 2 and cannot find the data, i.e., Total flight time, number of flights, etc.
If you go into the app without mavic or controller on along the bottom of the screen you will see a line of icons touch the one that says me and a sub menu will come up select flight records and all you flights will be there you need to be on the internet to do it then select sync and all will be revealed you can watch the data being played back and see where you flew
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
