Hello
Two weeks ago I got my MA2 from an Austrian store.
Today I noticed, that I have the non-ADS-B model (MA2UE1N). I didn't know there are models without AirSense. I wanted one with AirSense.
Can I somehow trade my non-ADS-B model for one with AirSense?
Hello
you live in Austria, right? As per DJI Support, ADS-B / Airsense Won't work outside US,
That's not true, they just don't sell the model with an ads b reciever outside the US due to covid mucking up the supply chainyou live in Austria, right? As per DJI Support, ADS-B / Airsense Won't work outside US,
I agree if the drone has it installed it should work worldwideJust to clarify - it should work anywhere since all it relies on is receiving ADS-B aircraft transmissions. It just isn't being sold outside the US.
I already contacted the DJI Support to ask whether the ADS-B Airsense will work outside the USA , As per DJI Support it will not work.
See our conversation below.
By the way I lived few kilometer's away from the airport and I don't received any warning from nearby aircraft.
Yes - and of course they could have disabled display of ADS-B data when the aircraft detects that it is outside the US, but I've already seen a couple of reports from people using the US version in Europe and receiving data. I suspect that's another misinformed DJI response.
Yes i hope so, and i believe that if the aircraft has a transmitter of ads-b and the drone's has a receiver of ads-b, It will automatically pop-up a warning on our map when there is a nearbty aircraft flying..
Unfortunately i have a missing option, on my Setting> SAFETY > Advance safety setting> if you scroll on the bottom you will able to see the switch button for air sense, But for me that part is missing i don't see it.
Tried to spoof my location on USA now it works I had an AirSence aerial disclaimer to enable air sense.
Are you saying that you have a non-US MA2 that now has working Airsense after you spoofed your location? Or was it purchased in the US and you are using it outside the US?
Sorry if i can't explain it clearly in english my bad.
It was purchased in US and I'm using it outside the US.
The thing is when i watched the youtuber BILLY KYLE how the airsense is working, during his flight there is a Aircraft nearby flying and it gave a warning that a manned aircraft is Flying nearby.
On my case i didn't receiver any warnings , Upon searching i saw a video that there is a switch button for airsense, But on my Setting that switch for airsense is missing.
Then tried spoofing my location to us, I'm doing that inside my house of course so that it can't received GPS signal. Then it gave me a disclaimer to enable airsense...
So basically if i'm not mistaken on my theory , IF the MA2 is on FCC Mode the airsense will also Enabled.
I was under the impression that only the US got airesense because of the lack of ADS–B hardware in the non-us versions because they ran out of parts.In other words is it a hardware difference or just a firmware switch?
Or a teardown video of both.We need an example of a non-US MA2 operated in the US to answer this.
