Air 2S, Camera Blurred, Gimbal works perfectly.
benniep9721
Johannesburg South Africa
I recently purchased a Air2s from an Auction site.
It arrived and even before firing it up, I could see crash damage to the camera area.
The Gimbal and stability are perfect, I have reset the camera settings, put everything on Auto and its still a blurry image. What damage could a crash have caused to the camera?
I have checked the cables and they are plugged in fine.
Hoping I don't have to replace the entire module.
Any advice would be appreciated.
Could be a lens issue. Did you carefully examine the lens for any dirt, scratches, or defects?
I must check the lens for distortion, but the middle is really blurred, the sides seem ok, if there are no scratches or dirt on lens, any way I can check for lens damage?
No scratches etc on lens, visually looks fine.
Perhaps lens isn't lined up properly with internal sensor. There a likely a lot of unseen possibilities after a crash.
Check online or direct from DJI. You may want to consider repair by DJI; check their support page; since you already attempted some repairs it might make a difference.
KevinStudent
