Air 2s waypoints?
bmoore1118
I am having no luck and wanted to see if anyone can help. With the air to S not being able to load way points onto the drone and using the so-called virtual sticks I am having issues finding a third-party app that isn’t super jerky when I use way points. Anyone have any success with this drone and a better app?
For others
Rod ..
There are no apps as far as I know that will allow what you want to do. I had an Air 2s two years ago and had the same problems as you are now having. Once again, it's DJI that is causing this and whatever app you get, you'll still have to deal with the virtual stick problem.
Reactions: High_Order1
Does the air 3s or mavic 3 store anything in the drone to make it less jerky
This video may help, The key is speed apparently.​
DJI Air 2S - Creating Waypoint Missions Using Litchi | DansTube.TV​
JrVolt
