Air 3 S v's M4P battery life
Can anyone who has moved from the Air 3 S to the M4P share your thoughts on the battery performance of 2 drones (ie better, worse, the same) ?
Many thanks!
Battery performance? What specifically are you referring to, that you are asking about? How are you quantifying or measuring battery performance?
It's a simple matter to compare the specs.
Max flight time
Air 2S - 45 minutes
Mavic 4 pro - 51 minutes
Both are measured under laboratory conditions:
Measured by the aircraft flying forward at a constant speed of 32.4 kph in a windless environment at sea level, with Obstacle Avoidance Action set to Brake, in photo mode, and from 100% battery level until 0%.
Reactions: KS-6
Going from Air 3S to Mavic 4 the battery flight time is better compared to Air 3S but not a whole lot more. The Air 3S was a much lighter drone when compared to the Mavic 4 Pro. I get roughly about 38 minutes in the air landing at 20% more or less. Noting that in NZ it is almost always windy.
ptweet
