I just came across this on the Alientech site. It has no installation instructions up yet but should be up in a few days.....
Looks like one might have to get deep into the RC to install the bracket.
The ALIENTECH Duo antenna works on 2.4G & 5.8G dual-band and can be enhanced the signal extender of the remote control for DJI
Mavic Air 1 /
Air 2 /
Air 2s drones. It is a high-gain passive directional antenna. It can extend the signal control distance of your drone.
alienth.cn
Alientech puts out great boosters, just recently installed one to my Evo 2 Pro but it was the Alientech Pro booster setup.
This particular one from your link is antenna setup only, no amplifier. Still, the antenna range extender minus amplifier may still probably increase signal transmission. It would need the Pro model to increase it even more.
With
Mavic Air 2 stock setup, that’s plenty you may not need the range extender minus amplifier. If I was to go out and do the mod on my
Mavic Air 2, I’d go all out and add the Alientech Pro amplifier setup. It’s very lightweight, probably the best amplifier out there for its size. Plus, User can change out amplifier setup and change to whip or other antennas in a few seconds If flying in an area user doesn’t need amplifiers.
I can actually use the Alientech Pro amplifier setup with the
Mavic Air 2 if I mount another set on connectors to
Air 2 controller, but will only be limited to 2.4 GHz manual. Same GHz as Evo 2 Pro. Alientech does have an amplifier model with both 2.4 and 5 GHz, but I’m not too familiar with that model.
When I added the Alientech Pro amplifier to the Evo 2 controller, that extra boost added a much stronger transmission signal to the Evo 2 controller. Now, the Evo 2 Pro surpasses my
Mavic 2 Pros transmission signal. Not by much, but enough to notice the Evo 2 Pro transmission signal is stronger than Occusync 2.
Good luck, I’m sure eventually we’ll be seeing members adding the Alientech Pro to there
Mavic Air 2.
They are nice, and easy to install.
Paul
