Thanks for the suggestion, but Ive already tried that with no real change. Ive unfortunately been on this sad ride (with many others) since Sept 2018 so Ive tried alot.
The ONLY thing that I tried that showed any worthwhile change to the flights range was by installing an older version of GO4 on my RC host device. The one I found the best results but they werent always as advertised, but always better than the normal 1000ft, was to use V4.3.0 (official-840)
(This is an android build. If your interested, its been posted in other threads that arent hard to find, with descriptions on where to find downloads. Keep in mind though; THIS OLDER VERSION DOESNT OFFER MANY OF THE UPDATED FEATURES out now, such as Waypoints 2.0)
The Pagoda antenna was made to match the 5.8Ghz band wavelength so if it helps on 2.4Ghz, its only due to somewhat close harmonics. Also, the SMA antenna input, on the
Goggles, was only ever added for the Analog 5.8Ghz range that Quad Racers use, with a separate transciever set that is placed on their AC.
Occusync 2 was advertised to have enough resistance to RF Interference, that it didnt need an external antenna on the
Goggles RE.
I believe the problem lies with the Go4 app, the AC and RC firmwares and coding, and how they all handle RF Interference.
DJI JUST NEEDS TO DO MORE TESTING IN DIFFERING RF ENVIROMENTS. The fix is possible, but the question is, is it profitable for them as theyve already sold alot of RE's.
Since DJI fixing this isnt likely at this point, I hope that these secondary fixes helps others but I remain unconvinced. I am glad that they seem to help some fairly well although I do believe its significantly location specific!
Example:
Mavic 1 and White
Goggles use Ocusync 1.0 while
Mavic 2 and
Goggles RE use Occusync 2.0.
Mavic 1 and White
Goggles DO NOT HAVE THIS RANGE ISSUE (Occusync 1 is 2.4Ghz only)
while
Mavic 2 and
Goggles RE, do have range issue (Occusync 2.0 uses dualband 2 4/5.8Ghz)
so I fully understand why folks think that using 2.4ghz custom (thus disabling 5.8ghz band) is where the problem lies, I do think theres more to it!
The difference between the Digital Protocols Occusync 1 & 2 is: Occusync 1.0 was still heavily hardware based, meaning they could only use 2.4Ghz as trying to add another rf band would require addl hardware (ADDING WEIGHT). They solved this by changing over to a software based system.
Occusync 2 is SDR (Software Defined Radio) based, so it is so much more, defined by software, (excuse the pun) than Ocusync 1.
The fact that range it ONLY affected when the
Goggles RE are linked to the M2 is because the
Goggles have their own GO4 -like- operating system.
So, the RC's host device (your phone or tab), The
Goggles RE and the M2 AC ALL HAVE TO COOPERATE IN REAL TIME.
The
Goggles RE added to that mix, when theres even the smallest bit of RF Interference, throws the whole system off, thus resulting in the BLACK WALL of zero signal that most folks hit once they reach 300m or so.
THE ISSUE LIES IN THE CODING DEEP WITHIN THE SYSTEM, MAINLY ON THE
GOGGLES RE SIDE, AND REALISTICLY ONLY DJI CAN FIX IT, SADLY!
THIS IS WHY THE
MAVIC 2 CAN CONTINUE ON FOR MILES ONCE THE
GOGGLES RE ARE POWERED OFF!
Sorry if this is more info than what was expected/hoped for. Im really just hoping DJI will suddenly give a crap about its not-so-old product and give us a real fix as everything else about the system is great!
