basically yes it takes a few attempts to get it right ,you need smooth stick control ,practice it by going further and higher each time till you get the shot you want be aware of any obstacles in your flight path as you go out, and what you are flying over, try it in Cini mode to start with as its nice and slow ,and one other thing beware of the wind as you climbThank you. Is this just a case of up and back?
Man.....this looks exciting!!!DroneLink has a Dronie mode which allows you to select how far you want your MM to go , also how high and how fast ;-)
