I have tried them and really saw no positive range increase.
Is there one you would suggest?
I own the Titan Switch for my Mavic setup. It's really terrific...but pricey. The reality is, the range of the Mavic controller out of the box is almost the range of the batteries and WAY beyond the visual LOS range...so you're not REALLY going to need an amplified antenna. The parabolics supposedly do work and give you a little better directional penetration. They would hinder coverage behind you, I would suppose...but if you're flying out where you're facing (and assuming VLOS, that's going to be true), they can give you a little more distance.
You can pick up one of these for like 10-15 USD. That's not cause for investment "worries". Get them and see if they work for you! Worst case, put them away and don't have lunch out that day!
- Gary
I heard that if you face the opposite way, it will give you troubles. Even fly away issues.
I just got my mavic air and I am getting video transmission issue past 200m in my neighborhood. Toronto, CAnada. I dont need max range. All i need is a stable video and little bit of range.
I just got 35,985ft there and back over the water Saturday on stock!
Yes, these concentrated range boosters are meant to give you extended range in front of you, not behind you. But they do work quite well.
The stock DJI antennae are omnidirectional, good no matter which direction you are pointing the controller. The boosters are limited in their rearward scope, but excel in flight in front of you, which is where people should be flying anyway.
I had a set of those Parabolic Antenna Range Boosters and actually had a drop in signal when I tried them, so in the bin they went and I went with the FCC mod, worked way better
I have never tried to fly my drone from inside a car especially a moving car! I'm not that brave.Well not always because what If i want to track my car? Will this work from inside the car?
Oh well.. I have seen people doing it.. Specially when you are a travel content creator.
I got one, used it for the first time the other day. Seemed to help in the 5.8 band not so sure about the 2.4 due to RF interference on that band.
I was flying it in my neighborhood. I had done a wi-fi analysis in the past here when setting up a 5.8 gig wi-fi link to my mother-in-laws house 2 blocks away so we could share Internet. The 2.4 gig band because of channel width is really only 3 channels, 1 6 and 11. I set up a high gain yagi and although we had good signal it kept getting interrupted by other homes. I then set up a Parabolic Grid array at both ends for 5.8 gig band that when carefully exactly pointed at each other worked well except in mid-summer when foliage is at its max. Antennas not high enough to get over our tall trees so I had to power beam straight through a lot of them.Have you tried changing channels?
