Have any mavic mini owner pushed their drone to climb above the low cloud? I mean taking off from almost sea level and climb until you are above the cloud, not taking off from high altitude.
the maximum altitude is 500m, so if the clouds are too low that will be possible
it means that will be the maximum altitude from the home pointI noticed the altitude setting. So is that means the drone will not allow me to ascend any higher?
Я пролетал над облаками в горах Словакии. Задача была сделать спуск, дрон не реагировал на клюшку. Включил Спорт и все закончилось хорошо. Я подозреваю, что мешали нижние датчики.
You could be lucky enough to catch an inversion.That Alt limit is Hard Coded into the Firmware. Without some extensive hacking you're not going to get it to ascend any higher than that level from it's take off point.
With that being said, depending the weather etc someone could, in theory, fly higher than the clouds at just a couple hundred feet.
Yeah, I was wild camping in the Lake District and caught a fabulous inversion with my MA.i have been up Snowdon where the clouds were below where i was standing ,on the Snowdon mountain railway station at the very top,it is an amazing view so if i had taken off then i would have been above the clouds,this was many years ago before i got into drone flying
Just fly above fog. When you're above it it will look like clouds below you, legally. It's a really cool view too.
Maybe not legal since it might be out of sight, even close to you, you can hear it though
Sorry about that, I added the second part as an afterthought, without removing the word 'legally' in the first one. I could remove it but I stand corrected.?? have fun fly safe.So, in other words, illegal!
