Slight accident today, you could'nt make up. so just seeing what's out there for repair.
Decided it wanted to land on a bypass, thank heavens it was only the drone that coped it.
So what caused it to land ?Yea me to.
From what I can gather it lost signal, this was what the controller showed, the vid just stopped with it hovering, i collected like this at its last location.So what caused it to land ?
Got the vid on my phone, it was hovering stable, no attempt to return home, the vid just ends and picked it up at the side of a road as is. Can't fathem what happened with the vid alone. the vid shows it just hovering and then the vid stopped.
Show me how?Oh noooo, this sound like a battery dis connect , our you going to post a log for the number grinders .
Way to big an assumption! It unfortunately sounds more like, if the OP checked the setting that it was set to RTH on loss of signal, that it might have lost GPS lock. However this is obviously also a guess & the flight logs would probably be able to say what happened.Oh noooo, this sound like a battery dis connect , our you going to post a log for the number grinders .
triWay to big an assumption! It unfortunately sounds more like, if the OP checked the setting that it was set to RTH on loss of signal, that it might have lost GPS lock. However this is obviously also a guess & the flight logs would probably be able to say what happened.
quote from user manual:
“The aircraft cannot return to the Home Point if the GPS signal is weak or unavailable. If the GPS signal becomes weak or unavailable after RTH is triggered, the aircraft will hover in place for a while before landing“
I do live in an area with a no fly zone, its a stadium, this as I live a mile away I applied for the licence to fly, I had this and all sorted. I was never going to fly anywhere near the stadiam and as its not in use atm I thought no problems. Most of my flying is round by my house close to the stadiam that I thought I had permission to fly around, not over as its the rules, empty or not. I think this was the issue, it did flag a warning before signal dropped out but as I applied for the licence to fly, recieved the code, imputed it to the fly app I was good to go. It was just this instance it all went wrong far to quick with no explanation from any Info I have to hand.Way to big an assumption! It unfortunately sounds more like, if the OP checked the setting that it was set to RTH on loss of signal, that it might have lost GPS lock. However this is obviously also a guess & the flight logs would probably be able to say what happened.
If I knew how I would. Let me search you tube and see if at all I can get more info.We could spend all night making guesses, how about posting the flight logs and seeing if one of the experts on here can tell us what happened?
