You might get somewhere near a consensus or opinion/experience if you search earlier threads and spend some time in the NLD forums.Been using it long? What is your consensus?
What you might need to consider is that you can’t fly with later software or app on the M2 and achieve what your seemingly intent in doing.
You might also find that DJI is getting better with the current GEO fencing. That’s is, at least has been my experience, areas that had big red circles now allow flight. I am on current firmware now and can say the areas that are locked arguably should be. Flying there as a hobby operator would be silly.
I’m saying you can’t run up to date firmware and/or current GO4 versions with the NLD solution as it exists now.I just thought I might get a more ture evaluation here than on the developers website. The ole conflict of interest 'thing', and I could be totally wrong.
Not sure I follow you. It sounds like you are saying that not having DJI/Go4 software up to date can cause issues?
My issue seem to mainly be with trying to communicate what I want when it comes to customized GEO fencing from DJI. It has been taking several e-mail rounds to get everything cleared up and in place the way my COW from the FAA states.
Thanks for trying to help me out.
mark
I'm guessing that you have not used it?I’m saying you can’t run up to date firmware and/or current GO4 versions with the NLD solution as it exists now.
I guess you don’t understand how it works. GEO database is in both firmware and GO4.The latest GO will work to fly but your intended outcome won’t be as you expect. Have a look at what the current fly safe database versions are for you. Fail!I'm guessing that you have not used it?
Here is a screenshot using the "latest" Go4 (4.3.17) on an iPad and it works just fine....
Granted it is Firmware ver 0.100 on the bird but I don't need Precision landing as I am perfectly capable of that myself and I have Litchi for Waypoints which is better than the DJI Waypoints.
If absolutely needed, I can remove NLD and reapply later....
At least when I show up for a job with a wavier, I won't get scre$#@ over by DJIs crap.
As you can see in the screenshot, I live in a now restricted zone and I can take off no problem with the current Go4.I guess you don’t understand how it works. GEO database is in both firmware and GO4.The latest GO will work to fly but your intended outcome won’t be as you expect. Have a look at what the current fly safe database versions are for you. Fail!
All you need to know is on the NLD website. I am reluctant to go into it here as I understand it would arguably be outside the forum guidelines. Not only that the NLD people know a lot more about it than we might ever know.As you can see in the screenshot, I live in a now restricted zone and I can take off no problem with the current Go4.
It was applied two days ago so maybe something has changed?
