Anyone Still Using Moverio BT300s with DJI Go 4 Etc?
AEMontoya
Bay Area, CA
Hi All. I recently got back into the RC hobby since 2019 (planes, helis, multis, ...). A lot has changed since then, of course.
I would like to use my Moverio BT300s with my Mavic Pro, and everything seems fine. However, I cannot download offline maps (they never load or show up in the first place, actually), and the DJI Go 4 app will not display maps in the mapbox.
FWIW, the DJI Go version on the BT300 puck is the one that came pre-installed from Moverio: 4.3.20. In 2019, I believe that maps--at least the offline ones--were available, as my DJI account shows about a half dozen maps that I downloaded back in the day.
I only put about 10 flights on the Mavic and BT300s combo, and so I never really learned a ton about how everythng played together, and nowadays the Moverio App Store is down, along with probably other changes I am not aware of.
With all that said: Is there anyone who still uses the BT300 with the Mavic Pro who could give me some pointers about how to get maps available in DJI Go 4?
Other potentially relevant info:
-On my Android 9 phone, which has DJI Go 4 4.3.37, which was last used back in 2019 also, the offline maps will show up successfully. However, I cannot download them due to what is claimed to be a "connection error," even though I have full internet connection.
Thank you in advance,
Andy
I use the Moverio 300 but with the smart controller and everything works good. Just plugged into the controller.
Thanks for the feedback! I guess your setups is a different animal than mine, though. The problem I'm having with the maps not showing I'm sure has to do with the Android puck that goes with the BT300 package, while you're using the glasses component of the system to simply duplicate the display of the smart controller. Unfortunately, I cannot even use your setup if I wanted, as the smart controller does not work with the Mavic Pro that I have.
Andy
Re Offline maps. Have you looked at OSMand+ . A great set of worldwide maps that are installed on a tablet and used offline. Roughly $30 to buy but then with lifetime updates. Look at OsmAnd for more info.
Neville
Queensland
Australia
hibachiwithus
