Are the short RC to Device cables compatible, between Mavic Pro and Mavic 2 Pro?
conchman
Puerto Plata, Dominican Republic
They seem to fit both remotes, however, the other day I had a remote not working with the Iphone cable, now I am not sure if its a faulty cable or if I got the cables mixed up and used the Mavic 2 cable on the Mavic Pro and they are not compatible.
Since I don't have an Iphone (was using a friends), I cannot test to see if its a faulty cable.
Yes, those cables are compatible. You can use any Micro USB cable.
What @msinger said.
There have been quite a few posts on this forum regarding the monitoring device losing connection with the RC. And in a lot of instances (not all) it was due to a poor cable. I have experience bad cables in the past. I had brand new ones go bad in a week! Then I caught on to the "Anker" brand of cable available on Amazon. If you ever suspect a cable issue, my recommendation is to get an Anker. Has never failed after months of use.
Reactions: Magilla Gorilla
The short ones for the side port are notoriously flakey due to limited shielding, far better to get a short full size one for the bottom port, perhaps with 90 degree bend to suit your device.
It's a little less neat in the hand but trying to line up to the phone port when you can barely see it is a great way to damage it.
I had some issues with my iPad and RC last year and after a number of times having the App disconnected I followed advice to use an genuine Apple cable and I'm pretty sure that fixed the problem.
gonzaales2s
