First take it easy on me. I have just started trying to edit videos. At the very end of this video, the edge of the tree looks terrible, what causes this? I have several other shots that the same thing is happening.
Did you happen to change the frame rate during those shots and not adjust when editing?
Im not sure what you mean by a higher quality Value? I used Davinci resolve and exported in full 4k. the artifacts are visible in the raw footage straight off of the sd card.The Tree Artifacts and residual Ghosting … most likely has a lot to do with the compression used.
When Uploading to YouTube it would be great to get Tiny files - … But actually the Bigger the file the Better (Often ) the quality.
It appears that this one Battled to compress the Multiple Moving Twigs in the Tree segment... so the compressor 'shares' its 'ability' offsetting the SHarpness for the Movement.
Usually a Good Rule Is Great Lighting -from the front (not the back)
… and if bad lighting then LESS movement (ie Night SHots) -
Bottom Line the Tree Can By fixed by using a Higher quality Value in your EXPORT -
