If your drone is set to RTH on loss of signal, it should do that and RTH when you lose signal, whether that is in flight or even after you have initiated autolanding.If you set controller to autoland, then lose signal, will the drone land or return to home?
If you set the controller to "auto land" then when the signal between the controller and the drone is lost, the drone will land wherever the signal was lost. the drone will NOT return to home.If you set controller to autoland, then lose signal, will the drone land or return to home?
You cannot set the controller to autoland when signal is lost.If you set the controller to "auto land" then when the signal between the controller and the drone is lost, the drone will land wherever the signal was lost. the drone will NOT return to home.
Yes, it is set through the Fly app in the aircraft. All parameters like that are stored in the aircraft. Sorry that I wasn't clear about that.You cannot set the controller to autoland when signal is lost.
That setting has nothing to do with the controller.
It's set inside the drone, so that it knows what to do when/if signal is lost.
If you set the parameter to "land" while you have communications with the drone and then lose signal, it will land at the position it lost signal. Personally, I cannot think of a situation where I would ever set the parameter to "land". If I am on land and lose signal, I want it to return to me. If I am on the water and in a moving boat and lose signal, I want it set to "hover" so I can go towards the drone until I recover signal. Does that answer your question?Question is still not clearly answered. If signal lost is set to rth. And you have signal and set to auto land and lose signal, will the drone continue to land or revert to rth?
Read post #2 again.Question is still not clearly answered. If signal lost is set to rth. And you have signal and set to auto land and lose signal, will the drone continue to land or revert to rth?
I know I explained it very clearly way back in post #2, but here it is again.I guess Im not being clear. Lets say rth is set for signal loss at beginning of flight. I then fly over a hill and hit autoland. Drone then loses signal, will it continue to land or rth.
So your question is what happens if the drone loses signal while it is in the process of landing - will it finish landing or will to stop landing and return to home?Lets say rth is set for signal loss at beginning of flight. I then fly over a hill and hit autoland. Drone then loses signal, will it continue to land or rth.
