Automatic takeoff
thierrypierres
Hello everybody. As a French newbie I have a question
In the automatic takeoff mode, the drone goes to an altitude of about 15 meters instead of 1,20 meter.
Is it normal ? how can I solve this and modify the alitude takeoff
Thank you
Thank you
When I use auto take off my M2P goes to 4 feet altitude and hovers. The controller tells me this on the slide bar that appears to actually do the takeoff. Can you post any screenshots? I may be misunderstanding.
Reactions: BD0G
Yes , in short when Precision Landing is enabled the Automatic Take Off will cause the Mavic to ascend to a higher altitude so that an acurate picture of the area below the Mavic can be stored. That way when the Mavic returns to land it can try and get the landing as precise as possible using that photo data as a reference. If precision landing is disabled the Mavic will not ascend as high.
Hello
I disable short precision landing but it still takeoff at about 15 meters !
What can i do ?
Thank you
Hello
What can i do ?
Thank you
Take off manually by moving both sticks down and in towards each other , this will arm motors , then move throttle left stick up and release , drone will lift up approx 3 feet.
MaxRichu
