Not a good idea.Why would that be a consideration?
[/QUOTE
not good
[/QUOTE
Working on a strategy when flying over area you don't want the drone to land because the battery reached a level, somewhere below 10%, and it says it intends to land. To stop this, hold the left joystick, throttle, in easy position for lifting, while flying the drone to the place where you can land. Now you can fly until the battery is 0%.
Working on a strategy when flying over area you don't want the drone to land because the battery reached a level, somewhere below 10%, and it says it intends to land. To stop this, hold the left joystick, throttle, in easy position for lifting, while flying the drone to the place where you can land. Now you can fly until the battery is 0%.not good
if you are trying to help new flyers, then your title would have been better if it had said(battery care dont run them down to zero ) just my opinionYou are absolutely right, something I try to avoid, but many who have taken a similar position are panicked and do something stupid.
Trying to get people to understand how the drone reacts in such a position.
But it is through realistic practice that you can handle such a situation if you happen to end up in this situation for some reason.
But this is a situation you don't want to practice.You are absolutely right, something I try to avoid, but many who have taken a similar position are panicked and do something stupid.
This doesn't make any sense. If you crash your craft because you ran down the battery to 0%, it would be no risk to them.DJI always thinks that you should be 200% on the safe side, the least risk to them.
And I can tell you that I personally am not DJI, but very much prefer to play it on the safe side, for my sake.
But I agree that all users should know about all of the mitigation steps, the stick control being the last resort. I would state it in order, like this:
How To Avoid Crashing Due To Low Battery:
That was all in my own words, but you should already know all of that if you have read the manual.
- Pay attention to the H symbol (RTH) on your DJO Go Battery Level Indicator Bar. This means not flying out father than you can fly back. Also note that conditions, such as wind, could modify your return flight.
- Do not ignore the Low Battery warning (Recommended setting: 30%). This is the point that you should start looking for and being aware of any potential emergency landing spots. If you are over water, this is especially a good time to look for the nearest land.
- If you are still flying when the Critical Battery warning is reached (Recommended setting: 10%), the craft is going to land where it is and you will have limited control over where it will land. You can use the sticks to adjust the forced landing spot, as follows: hold the left joystick, throttle, in easy position for lifting, while flying the drone to the place where you can land.
Note: Running the battery down to 0% is not good for the health of the battery (even if you manage to land safely).
I suppose it would not be a problem to practice this once, in a controlled environment, such as in a large open field at a relatively short height OGL. After a normal flight, hover the craft until it dips below Critical Warning state and observe / note the amount of control you have. You don't need to run the battery down to 0% — you can set the Critical Warning to any level and you should be able to land with something over 5%.
But if you do this often, you're taking risks that you should not recommend to other users.
Chris
It’s the same stupidity to run the car and don’t fill gas until the fuelmeter says empty and the car stops at the highway.?
It's even worse than that, because it causes the gas tank to puff up and die prematurely.
