That setting defaults to 10 days and cannot be changed on Mavic 2 batteries. The workaround is to only charge the batteries you're actually going to use.Is there any work around for this, besides have to drain them manually?
That is unfortunate. Would it be possible with nolimitdronez?That setting defaults to 10 days and cannot be changed on Mavic 2 batteries. The workaround is to only charge the batteries you're actually going to use.
That's how I need to do it too ... the Battery to Power Bank Adaptor was delivered today, so I after a flight, I fully charge and if I am not able within 3 days to fly again, I'll charge other devices with it (let's see, not sure, but as I have 4 batteries, that may be too much still).
How do you hook up your DJI batteries to it?I have 4 of these- they work great!
ISDT FD-100 Smart Control Discharger 80W/8A Discharing Capacity 2-8s 6-35v Lipo Ba... Amazon.com: ISDT FD-100 Smart Control Discharger 80W/8A Discharing Capacity 2-8s 6-35v Lipo Battery Discharging with Maximum 80W Capacity Discharging Current 0.5A-6A: Home Audio & Theater
Does anyone have experience with this?
1.5A Discharger for DJI Mavic 2 Pro/Mavic 2 Zoom Battery https://www.amazon.com/dp/B07M82M42Z/ref=cm_sw_r_cp_api_i_-0A9CbJ60ANPE
As I write this I have one MAVIC2 battery being discharged to 60%. Have used it 5 times now and find it works very well. Not quick but then you don't want to discharge too quick .. nice and gentle. Can discharge to 0% or 60% .. auto turn off.Does anyone have experience with this?
I know in previous drones you could change the timer for the smart battery to auto discharge. There does not seem to be this option anymore with the M2P. 10 days seems to be a bit to long. Is there any work around for this, besides having to drain them manually?
Any length of time a LI-Po is left fully charged, will shorten its lifespan. Being a day or ten days. I rather drain mine to a safe level and maintain them for years to come. These batteries are not cheap.Why do you think 10 days is too long?
How long would you say it takes to drain one down to 60%? Think I am going to give it a try. Don’t need anything superior to this if it gets the job done, nice and simple.As I write this I have one MAVIC2 battery being discharged to 60%. Have used it 5 times now and find it works very well. Not quick but then you don't want to discharge too quick .. nice and gentle. Can discharge to 0% or 60% .. auto turn off.
What I wonder even more, is why the option to change how many days, was removed.Agreed - I've just not seen any scientific studies that demonstrate the damage due to short-term, fully-charged storage. DJI have presumably done as much testing on this as anyone, so I wonder what led them to select 10 days.
About 1.5 to 1.45 hours. I connect the battery, 2 presses on the battery switch the discharger does it thing.No need to sit around and wait as it turns of when target reached. I read somewhere that after 20 charges you should drain battery to 0% and recharge. This discharger can drain to 0%. No need to connect to a power supply. Can start the discharge straight after flying while driving home if you want to.How long would you say it takes to drain one down to 60%? Think I am going to give it a try. Don’t need anything superior to this if it gets the job done, nice and simple.
