Battery charging via hub
mavicpro@2018
Sweden
This is the third time I charge three batteries in the hub. Is it normal for it to take four hours?
I charge around 20-25% when the drone warns of low battery.
Just in case you aren't aware, the hub charges the batteries sequentially and not simultaneously...I believe it charges the one with the highest leftover charge first.
If I would have known that sooner I would not have bought my triple charger, I just used mine for the first time and made the discovery and was going to post my findings, glad I saw it her first
Why? The battery charger is only specced to charge one battery at a time, all the hub does is make it so you don't have to change them manually, creating a charger that could charge all 3 at once would cost quite a bit more
Reactions: fly_idaho
It's a little slow but it's sure better than having to hook them up one by one.
adsjr
