Hi All,
Whilst flying to perform a survey of a mine waste dump recently, our Mavic pro 2 just fell from the sky. The iPad simply showed 'aircraft disconnected' with a black screen. We managed to find the drone, thankfully just a few scuff marks and one broken prop as it landed in a bush to break the fall. All I can find in the flight log is "Battery Communication Error", with the battery useful time dropping from 1547 seconds to 0 in 0.1 seconds, everything else seems fine to me, but I may be missing something so any advice would be appreciated. The battery was checked visually and other than a scuff on the outer surface, it seems fine. It has since been charged and used in two test flights with no issues, so I am suspecting that the battery was not clipped in properly before the flight. The battery was found about 15m away from the aircraft, I don't know if it separated in the air or on impact, either way, we have ordered battery retention straps for all out Mavics. The pilot was using GSP for a pre-programmed flight using waypoints and he has about 620 hours flying experience (although mostly with Phantoms). Any advice that anyone can give factually based on the log would be appreciated as we had a similar incident with a Phantom Pro 4 only a week earlier (posted in the Phantom thread)!
Keep flying, keep safe!
