battery ERR. Over/Under Current
MavicFT1P
Hi
I just wated to know which is nore likelier.
Ive been getting battery discharge errors with some new batteries.
I had to replace a battery as over time these discharge errors seem to increase and make thr
Aircraft unsafe.
I think I've have narrowed it down to 3 culprits. So I need you help..
- Number one would be: Pinning the throttle in sport mode for extended periods
-Two: Having OEM parameters for acceleration and velocity changed in NLD to 10 or -10 and pinning it as
mentioned in the first.
Three: Running Non DJI Battery' setting in Asssitant 2.
In your opinion which of these is the most likely reason for what I am seeing.
The battiers have not been discharged lower than 30 percent yet so that's not a factor yet.
Thanks
What Mavic is it and what is the exact error message?
You might want to post your flight log here.
In the event log maybe there are some hints.
Hi
Aircraft unsafe.
Thanks
The first two. 10 acceleration is nutty especially for extended periods of time. With great power comes great responsibility
Reactions: charliesRig
The first two. 10 acceleration is nutty especially for extended periods of time. Will great power comes great responsibility
Drone is a m1p
I agree.
I only use '-10 vel' in at least one mode in case I need to get down quick.
Can be a life saver.
And -10 vel is less strain on the ESC/Battery.
not to ask tow questions in one thread.
But come somone link me the most user (noob) friendly log reading tool?
cheers
Drone is a m1p
I agree.
cheers
He I use -10 all the time but the 10 is the part that’s nutty.
Reactions: MavicFT1P
Jamn Java.
Check that. **** windows 10
lol I hope have a clue how to decipher what this deciphers.
Battery Err seem to disappear using max of 7 up, even pinned %90 flight.
-10 as expected is idling almost.
As long as it isn't option 3 causing a buildup on bad batteryiness, im good with that.
Took one of my new batteries down to %14 today.
I suppose all you can do is try and not do that often, eh
Reactions: brett8883
cyskka
