Ranger One here. I have made 33 flights with my brand new
Mavic Air 2 and had only a couple of install messages that firmly seating the battery seamed to help.....
Till now....One by one each battery my last outing failed to work. All they will say is installation error. Check to see in your batteries are installed correctly. Air craft will not fly.
I found if I push down and aft with the drone pointed straight up, the battery makes contact and says ready to fly all is correct, till I level out and the message comes back.
I have measured the battery with a straight edge to check for swelling and have none. All detentions check out. This has happened to all three batteries from my fly more combo.
Do you think it’s the batteries or the drone? I can’t believe an drone costing $800 would be warn out in 33 flights. Flight time of around 20 minutes and returning to home at the standard 20 percent level. It’s strange to land with 12 minutes flight time left but that is better for the batteries and the drones ability to get back home safely.
It was said about the contacts to tweak them but that didn’t change my issues any. Was wounding if you have any ideas. Sorry for the length of this. But my drone is down and I don’t know if I have to buy new batteries or send my drone back.
Any ideas?......Drone Ranger (Ranger One) clear for now.....
