- Joined
- Dec 24, 2018
- Messages
- 17
- Reactions
- 22
Hello all. I had a crash the other day due to an unintentional low speed, low altitude meet up between my drone and a cable. I retrieved the drone and there was no damage visible. I did a full pre-flight again and put it back in the air for a short hover and very limited flight to see if there were any issues not visible in pre-flight. Everything worked fine. When I was recharging the battery later, I noticed only 2 of the 4 arcs of the circle light up when charging or pressing the button to check charge level. However, if I put that battery in the drone and power on/connect, the DJI app shows it at 100% charge. While on with app showing 100%, a press to test shows only the 2 lights.
So, should I be worried about the viability of the battery from the crash with two lights out, or should I go with app reading that all is well? The drone flies fine on the battery, but I am curious if anyone here has any similar experience and can share if I am on borrowed time with the battery so I don’t find out mid-flight in the near future!
Thanks!
Thanks!
