Battery power restricted
britdub
Uk
I had an error pop up and a second later it was gone, not enough time to read it I can't find errors in the DJI app so I looked in airdata and this is what it showed
Battery power restricted. Aircraft performance decreased to ensure flight safety. Return to home promptly (Code: 110013)
Flight time: 00m 56s
Altitude: 90.0 m
Home Distance: 63 m
Why show such a critical warning for 2 seconds ? Why not leave it on the screen like they do with the high wind warning ? I'm concerned about using this battery again.
Regards
So this looks to me like you need to update the Battery as there was an issue with flying out about 150 ft or so and stopping.
Check that first to see if the battery needs to be updated.
Phantomrain.org
Gear to fly your Air 2 in the Rain and Land in the Water.
Reactions: britdub
Phantomrain.org
Thank you for your reply, I've checked all of my batteries and they are all up to date, do you think I should email DJI and ask them for an explanation of the fault ? The only thing I can think of is it was cold -2 or a little colder
Ok than yes the cold cold have been the Issue , on the battery.
Once it warmed up the warning went away , that makes sense.
You should consider getting the Air 2 Wet Suit as it comes with 3 Battery Covers each 3mm Thick and keeps the Heat in the battery when sealed. We offer the Forum members a nice discounted package.
Email me at [email protected]
Phantomrain.org
Gear to fly in the Rain , below zero weather .
I've gotten it twice both times, the voltage dropped
Reactions: britdub
petravka
