BBC News - Yemen soldiers killed in Houthi drone attack on base
"Shaped Charge" to focus blast and shrapnel downwards towards targets.
Dust and debris coming from below indicates where shrapnel hits ground at an angle and creates dust and particle debris.
Shaped charge - Wikipedia
That was pretty gnarly!
that wing is from something a lot larger than any drone used here in the USA. but there might be a couple rc controlled fixed wing airplanes out there.
the military has been using drones to kill the other side for years now, good or bad use, depends on whose side used it.
and just about everything has been, or will be tried to be used as a way to chop off the ranking people on the "other" side.
Reactions: Inspirephil
That was a fixed wing drone with a larger main wing and a smaller front sort of canard wing. It was not a quad copter drone.
HMZ
