Best lights
NikkiSixx
Are lume vibes the best route? I’ve seen people post about magnetic interference when using them
I have used them with no indication of interference at all.
As for if they are the best.. depends on what you want them for
Are you referring to Lume Cubes? If so, they are viable option if you're goal is to light up the flying area. The tradeoff is the weight -- which will reduce the flight time and agility of the aircraft.
75651
If you just want to be able to see the drone easily, then strobe lights would be a better option. Here are some commonly used strobe lights:
If you decide to go with strobe lights, I make Mavic 2 mounts for all Flytron and Firehouse lights. You can find them in my store.
Flytron STROBON Cree Mounts
75652
Firehouse ARC Mounts
75653
Firehouse Dual Mounts
75654
shandilya
