Blurry Pic
rayrod354
Took this picture at work today from about 70 up. But most of the ones I took were a bit blurry. How can i correct that? Thanks.
Were you asking if there was a way to correct the out of focus image after the fact? There are sharpening tools in popular photo editors , but those can only do so much and I think they will no resurrect this image.
Work on your technique, check your focus and shutter speed and take more shots so you have options. You can do a lot of things in post but correcting focus isn’t one of them. As is often the case this seems to happen when a lot of people are expecting to see the final result. I think we all get caught out occasionally.
Reactions: Geoff9251
You can't fix a blurry image like this in post, you should have focused prior to taking the shot.
testtest
