My drone had a bad crash yesterday. As you can see the front glass is shattered, but the clarity of the camera is still the same. Does this mean the protective glass was shattered and the camera is okay? Is there a way I can fix this? Thank you
You have to send it in probably, My Inspire 2 crashed, and there doesn’t seem to be any sort of damage to the camera, just the gimbal. I’m saying the camera is probably okay.
What's outright smashed is the lens cover. Hold the camera housing, then push in and turn CCW the frame of the broken lens cover, it'll come right off. If the lens of the camera, behind that, is not damaged, you should be good to go on at least that part of the damage. Replacement lens covers are available.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
