Calibrate IMU and compass message will not go away under the safety tab even after I successfully calibrated the compass and IMU. Any idea why this is happening?
MM2, Fly App v1.3.0, 7 hours total flight time starting in Jan 2021, 130 flights. Android Samsung Galaxy Note 10.Not based on the extremely limited info about the drone, SE version, previous flights, and how long you have had the drone
I recall the IMU or compass status used to say "normal" or something like that, and the "Calibration needed" status message would show up infrequently only when something was off. So what you are saying is now the IMU and Compass status defaults to "Calibrate"?if it just says calibrate your compass and the same for IMU then that message is always there, it's if you want to calibrate either your compass or IMU then just click on the message otherwise just ignore it
