KX4SAM Active Member Premium Pilot Joined Sep 21, 2022 Messages 28 Reactions 44 Age 69 Location Summerville, SC, USA Oct 12, 2022 #1 I have a hard case, do I need the camera gimbol guard on while in the hard case?
TruGreen Well-Known Member Joined Jan 31, 2019 Messages 526 Reactions 346 Age 37 Location Hemet, California Oct 12, 2022 #2 I would just because it helps hold it secure and not bounce around loosely Reactions: GadgetGuy
Wild Drone Pilot Well-Known Member Joined Feb 12, 2018 Messages 363 Reactions 166 Location USA Oct 13, 2022 #3 KX4SAM said: I have a hard case, do I need the camera gimbol guard on while in the hard case? Click to expand... Yes you do It's better that way
MA2 317 Spark 2017- 2021 MA2 2020 - ?? Premium Pilot Joined Aug 20, 2020 Messages 6,191 Reactions 35,192 Location Indiana, USA Oct 14, 2022 #4 . Keep using the gimbal guard. Even it means modifications to the case via carving foam away for clearance. The gimbal is the most expensive part of the aircraft to repair from a "minor" incident. The gimbal cover is the last thing I take off before flight and the first thing I put on after a flight when powering down. .
