Camera Polarizer
Look at me I'm flying
Ireland
Hi. all I tried to fit a camera polarizer to the pro platinum and twice it has overloaded the gimbal and stopped it from working. When I take it off and turn the drone off and on the gimbal resets itself and is fine again.
The brand of polarizer is Ultimax and is very small and light.
Make sure to put the gimbal clamp on when you install the filter and make sure it is all the way installed. It should be pushed as far as it will go onto the lens and all the sides are evenly and completely flush with the camera.
Do a gimbal calibration once you have it fully installed. The filters are usually really tight when new but it will loosen up and be easier to install after awhile
Thanks brett8883 to me it never really felt like it was sitting on properly but I have pushed it on fairly hard with the clamp supporting it.
I will try putting it on again and calibrating the gimbal with it on.
This forum is fantastic people really make the effort to get back to you fast.
Reactions: mereflyer
bbj5143
