Can only connect with 2.4 ghz to SC
skunky1
ZA
So I was battling to get my iPhone to connect to the hotspot of the SC until I found a fix wherein you need to change the settings from the default 5ghz to 2.4ghz.
The downloads will be faster on 5ghz.
Is there a fix for this ?
I have no answer, but have you tried just using the SC "GoShare" function and transfer files that way? I had no idea that the SC had hotspot, nor why it would as it doesn't have any service connected to it to provide Wifi out that I have ever seen.
Yes the “hotspot” is the goshare function which essentially connects your phone via WiFi to the SC as a hotspot to transfer the files.
Just that only 2.4ghz works
I have the same experience olny 2.4 Ghz is working.
venoom2001
